Brief Description: Left leading edge installed on wing
Installed the stall horn switch and wired it in preparation for the leading edge to be attached to the main spar. I increased the bushing size (one size) so that the stall horn wires can be placed in a loom. The loom will go from the switch to the main wiring conduit in the wing. The left leading edge was installed and the wing cradle was finished to accept the new wing. I started work on the right leading edge... getting the primary leading edge assembled, drilled, disassembled, deburred and scotchbright. Next is dimple and prep for paint. Because the Auto Pilot is in the right wing, Auto Pilot bracket has to be installed before the right leading edge is installed.
