Brief Description: H. Stabilizer and elevator install
Finished the aileron control adjustments. All connections torqued and sealed. I gave the pitot tube a new memory at the wing root by applying 450° from a heat gun. Two areas were turned 90° allowing the pitot line to exit the wing and enter the fuselage well clear of the fuel line and aileron levers. Also cut and installed the green and blue AOA air pressure lines. The horizontal stabilizer and the elevators were installed. Trim control is next to be installed.
