TERRY'S WEB SITE
Date:  9-23-2013
Number of Hours:  6.00
Manual Reference:  Section 32
Brief Description:  RG400 wire run
Worked on the wiring runs today. First was to come up with a way to install the RG400 coax later and to do that I installed 3" of Pex water line to use as a conduit run. I wrapped each end with safety wire to keep it from sliding through the bushing at each end. Worked well. I then made a couple brackets for the main battery wire and installed the wire cover on the left forward. Vans does not make one for the right side, so I plan to order some aluminum and make my own...just like the one on the other side.
Pex tube used to guide RG400 to antenna
Pex tube in place
Pex tube in place
Safety wire holds pex tube in place
