Swinnys 4 Place Bush Explorer
BushCaddy L164
Engine connections
I re-installed a section of the right rear baffle quadrant and installed the fuel hose to the distributor, then started on the EGT & CHT probes.
I also changed the oil drain fitting due to the exhaust pipe from cylinder 4 touching.
EGT & CHT pots 1 & 3
Fuel host to divider installed.
New (second hand) oil drain fitting
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
