Brief Description: Final installation of the Brake Cylinders
After painting and installing the re-made doubler plates under the Brake Master Cylinders and rudder bars, I re-assembled the Cylinders and Brackets.
Adjusting the brake action in each pedal so that you get a reasonable line up of the pedals takes a little effort leaning in through the cabin framework. I can't imagine doing this with the cabin sides skins installed or the instrument panel in place.
