I decided to mount the park brake valve in the centre of the inside face of the firewall mounted on a section of angle running horizontally between the two firewall stiffening angles, with the of only using the flexible Nyloseal tubing from the cylinders to the valve and then the 1/4 aluminium tube down to the cabin bottom skin.
