Swinnys 4 Place Bush Explorer
Date:  1-24-2015
Number of Hours:  7.00
Brief Description:  Engine connections
A week at the beach is just the bees knees with this hot Brisbane weather, but it doesn't help progress when you are getting close to starting the engine for the first time !
Today I installed the Plasma 11 ignition wires and carried out the "Phasing",
Used the starter motor for the first time to turn the engine! It worked just fine.
Installed the scat blast tube cooling pipes to the Magneto, fuel pump and the Hall Effect module of the plasma 11 electronic ignition.
And installed the oil cooler box & 5" SCAT duct for the final time.
very satisfying day 1
Coax Plasma 11 ignition wires connected
Scat tubes in situ.
Scat tubes in situ.
Oil cooler duct box final install.
