Swinnys 4 Place Bush Explorer
BushCaddy L164
Final install of baffles & Ehaust stays
I installed the spring wires holding the baffle lower cylinder shrouds agaist the cylinder heads and then installed the Exhaust pipe stays.
Also installed the blast air scat tube cooling the Alternator.
Engine baffles wired
Exhaust pipe stays installed.
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
