Swinnys 4 Place Bush Explorer
BushCaddy L164
Access panel supports to underside of left wing.
I decide not to use the 0.016 'U' channel and instead used the 3/4 X 3/4 X 1/16 2024 angle to form the support framework for the access panels.
I will use plate nuts for the access panel screws
BushCaddy L164 Home
3616
A/Filter & Snorkle
Ailerons
Brake systems
Cabin
53
372
Cowls
Doors & Windows
Elevators
Engine Baffles
Engine mount
External lighting &
Fairings
Final Assembly & Ins
Firewall fittings
First Flight & Tests
Flaps
Flaps
Getting sidetracked!
Horizontal Stab.
Instrument panel
Interior Lighting
Internal linings
Kit delivery
Paint Shop
Prop & Spinner
Seat Belts
Seating
Static System
The A P Inspections.
Undercarriage
V-Stab
Vert-Stab
Wind Screen
545
Wiring
