Deburred holes in Right Wing Ribs and Main Spar. Prepped and primed Right wing Ribs and Right Aileron Bracket parts. Clecoed and riveted Right Wing Ribs to Main Spar. Installed and torqued right rib bolts as per directions. Riveted Right Aileron Brackets together. Edge deburred W-1007D's, W-1007E and W-1007A-R. Marked W-1007D's (Right) as per instructions and match dirlled #30 and #40 holes. Match drilled #30 and #40 holes in W-1007E. Deburred right W-1007B and W-1007C and clecoed to Rear Spar. Match Drilled #40 holes in Left Wing lower Rear Spar flange and Lower Aft Tab of Ribs.
