Marked and drilled right trim tab hinge as per Steps 1 and 2. Clecoed, clamped, and aligned hinge to Right Elevator. Match drilled #40 holes in hinge. Clecoed, clamped, and aligned Right Trim Tab onto hinge. Match drilled #40 holes in hinge. Marked and trimmed hinge to right elevator and trim tab. Bent and cut hinge pin to fit. Drilled 1/16" hole in elevator to secure hinge pin as per instructions.
