Completed disassembly and deburring of holes in left elevator. Clecoed reinforcement plates to E-1002 Right Elevator Front Spar and match drilled #30 holes. Clecoed E-905 Root Rib and E-1002 to E-1001B Right Elevator Bottom Skin. Clecoed Right E-1008 Ribs to E-1002 and E-1001B. Clecoed E-1007 Right Rear Spar to E-1008's, E-905, and E-1001B. Match drilled all #30 holes and the two holes in the outboard end of E-1007 Rear Spar. Clecoed E-1022 Shear Clip inboard position as directed. Clecoed E-1015 Trim Access Reinforcement Plate to E-1001B. Final drilled #40 holes commmon to E-1015 and E-1001B and nutplate attachment holes. Clecoed E-921 Elevator Gusset in position and final drilled #30 holes. Clecoed E-1022 Shear Clip to outboard Rear Spar. Clecoed Outboard Tip Rib Assembly in position and final drilled #30 holes as directed. Clecoed E-1001A top skin to right elevator. Clecoed E-1023 Trailing Edge Wedge in position. Match Drilled #30 holes in Skin Close Out Tab and inboard E-1022 Shear Clip. Clecoed WD-605-R-1 to Right Elevator and final drilled #30 holes as directed.
