Clecoed in F-1011 and F-1012 Assembles and F-1079. Clecoed on right F-1073 and match drilled all common #40 holes, again except for the F-1032 holes. Installed the Whelen Power Supply bracket from Van's. Installed and match drilled the F-1055 rudder stop skin stiffeners and checked for any twist in tailcone. Installed and match drilled the F-1056 rudder stop brace. Installed F-1006 and match drilled the #30 holes common with the F-1029's only. Installed the F-1028 bulkhead channel and match drilled the common #30 holes with F-1006 and the F-1029's. Deburred F-1037B and F-1037C, installed and match drilled them as directed. Cut, deburred, and marked F-1010B as directed. Installed the F-1032's. Deburred and installed F-1014 and F-1011B along with F-1010B. Match drilled #40 holes common with F-1012A and F-1012B, and with F-1014. Clamped the left F-1032, and F-1014 as indicated. Match drilled the #40 holes common with the left F-1073 and F-1032.
