Edge deburred all bulkhead frames and match drilled #30 holes. Final drilled 5/8" holes in F-1007 as directed. Cut, notched, and bent the F-1032's Left and Right. Set up F-1078 on saw horses and began clecoing on the bulkheads. Deburred and marked the F-1047 J channels just prior to installation. Match drilled the #40 common holes in the F-1078, the bulkheads and J channels except for the outer edges of F-1078 and side skin holes.
