Match drilled right side of R-1001, removed it from angle iron budking bar in order to clecoe on left side. Drilled hole in R-1004A to accept 5/8" conduit for wiring of taillight/strobe should I route in through the rudder skeleton. Match drilled left side of R-1001. Added holes to accept MK-2000-3 and K-1000-3 nutplates on left side at trailing edge of R-1003A and R-1015F-L in order to mount Static Wicks.
