Retorqued all AN3 nuts to 33in/lbs to account for 8in/lbs friction in AN365 nuts as per Van's suggestion. Did not retoque nuts in HS as these were originally torqued to 30in/lbs (within specs). Installed Static Line to left and right Static Ports. Retorqued AN4 bolts to 60in/lbs to account for AN365 nut friction. Cut mounting plates for rotating (flashing) beacons. Laid up fibreglass on VS Fairing for rotating beacon mount.
