Brief Description: Drilled Top Skin to D Spar Right Wing
Today I took about half of the Clecoes out of the top skin and triple checked the wing for twist. I used my prop adjusting level at the aft end of the wing on both ends--on top of Rib # 11 and Rib #1. This is good, right on the money as both ends are parallel. 1. Once I was satisfied with the trueness of the wing I clecoed the skin down to all ribs and drilled the leading edge to the front spar. 2. After drilling the spar and skin, I deburred both sides of skin and both sides of spar.
