STEPHEN'S WEB SITE
Date:  2-3-2018
Number of Hours:  3.00
Brief Description:  Assembled Bell Cranks
1. Used a 5/8" drill bit to clean excess paint from tube that holds spindles on all 4 bell cranks. Just turned by hand, did not need to use a drill motor. It did not take much effort to cut the excess paint.
2. Pressed in all 4 bearings by hand. Tapped in tight with a 1" socket that only contacted outer race of bearings.
3. Assembled bell cranks. Used blue thread lock (Premitex) to lock aileron spindles.
4. I did not safety wire the aileron spindle bolt yet. I will order safety wire and do this when I get the wire.
Pressed in Bearings
Pressed in Bearings
Tapped Bearing in Tight with 1
Tapped Bearing in Tight with 1" Socket
Assembled Flap Bell Cranks
