Brief Description: Drilled and Riveted Bottom Skin-Left Wing
Finished drilling the trailing edge of the bottom skin on the left wing. I used a twistie deburing tool(drill tyoe) and debured each hole. I vacuumed out all the shavings from inside the wing. After drilling I lifted the skin and cleaned any shavings from between skin and spar prior to riveting. I tried to debur the under side of the aft spar top flange but it was impossible to get to most of the holes. The burs were minimal and should not cause any issued.
