Brief Description: Cowling fitted and mods started
Over the past week (mainly the last 2 days) I got the fiberglass fitting well. All of the hinges are in place and I removed it so I could fiberglass the top seam together as I am doing the canopy split mod. This will allow me to remove the top half on preflight as well as for maintenance. Once the top is cured I will be adding a scoop-like fiberglass peice to the top so I can clear my secondary ignition and my oil breather housing.
You can see the intial fiberglass in place on the top seam
