Brief Description: Aligned skin and installed tail push rod
I drilled the #9 rib stiffener braces and got the lower aft skin aligned and ready to drill but I also got the tailwheel push rod installed. I don't like the way it is sitting and it will need modification or replacement. It does not sit along the rudder control horn as it should.
