Sonex 825 build log
Date:  9-9-2012
Number of Hours:  12.00
Brief Description:  Cowling fitted and mods started
Over the past week (mainly the last 2 days) I got the fiberglass fitting well. All of the hinges are in place and I removed it so I could fiberglass the top seam together as I am doing the canopy split mod. This will allow me to remove the top half on preflight as well as for maintenance. Once the top is cured I will be adding a scoop-like fiberglass peice to the top so I can clear my secondary ignition and my oil breather housing.
You can see the intial fiberglass in place on the top seam
Just the engine sitting pretty
Another view of the cowl from the top
