Sonex 825 build log
Date:  2-7-2012
Number of Hours:  4.00
Manual Reference:  SNX-W16
Brief Description:  Aft ribs are done!
I got all the aft wing ribs trimmed for clearance, which took longer than I expected. I also got all the gussets updrilled, deburred, and riveted in place. the rivets closest to the forward edge were a little close and I did not want to risk bending them out of whack (technical term). I started off hand riveting them but after about 3 ribs I had an epiphany. I figured I could use a chuck of aluminum with a hole in it to extend the head of my rivet gun. It worked like a charm! I also had to do some maintenance on the rivet gun. I has not seen action in a while an was in need of some hydraulic oil to start popping rivets with ease again.
My little rivet head extension
With the rivet gun in place
All the aft ribs complete
