Brief Description: Rear channel riveted and no warp!
I got a reply from Kerry and he told me I needed to install the rear channel. It was previously installed but only with clecos in case I wanted to remove it, which I decided to do to get to the bolts easier and to put all of the veryical stab together as an assembly and install the whole rear section at once. No deviation from the plan, just a different order I guess. Well I riveted the channel in on the right side and re-torqued the tail down and there was no warp. I guess the rear channel stabilized the longeron enough to keep it straight. I am at a holding point on the tail until my new stabilizer nutplates come in which UPS tracking says tomorrow. I started my tail fairing cut outs as well to kill some time.
