I didn't like the way I had run the pitot and static lines under the side rails...so spoke to Vans and later kits had an additional hole through the spar, which they said I could add...so...those are under the floor now, alone with the AFS AOA lines.
In following with doing things twice, I also drilled the hole in the canopy C-661 slide block...setting it too low by about a 1/16th. Ordered a new one....grrr.
