Brief Description: Left Grove Gear Leg and Brake Line
Installed the left, just like the right. None of the bolts are torqued yet, because I can't do that solo....but I'm a little concerned about the alignment of the gear. You see, I bought this kit from someone who had already drilled all of that....and I've been stressing about it being right. The left gear is sitting a bit odd.....I hope it tweaks over a bit when the bolts are properly torqued!
