Well, I've been putting this one off a while. I've never bent fuel lines before and never flared a fitting. I'll admit it, I thought it was going to be difficult. In the end, it wasn't really that bad. It took a while to get the hang of it, but in the end I made the right wing line in one attempt, out of one piece and no joints. If I put in a purge valve, I'll end up cutting that work of art in order to tee into it, but for now...it remains as is.
The supply line stops short because I am considering putting the fuel filter there. My thought is it would be easier to get to at annual than putting it up by the firewall....but I'm not entirely sure that is true once the panel is installed. I'm still on the fence on that one.
It's not touching the floor...just a camera illusion
