Sid & Houston Mayeux Project
Date:  2-26-2014
Manual Reference:  SB 14-01-31
Brief Description:  SB 14-01-31 part 6, fabricating the main rib forwa
The SB kit included a length of 0.035" x 1" angle for fabricating new flanges to replace those we cut from the main ribs. I cut them to length, edge-treated, then bent them inward to the prescribed bend angle. I cleco-clamped them into place on both sides to ensure the bend angle was correct (both sides of the angle should sit flush against the rib and spar doubler faces.
Cutting and bending the angle lengths
Clamped into place, checking the angle bend
