Sid & Houston Mayeux Project
Date:  11-29-2010
Manual Reference:  vert stab
Brief Description:  Rear spar, doubler, and rudder hinge mounts
Started work on the vertical stabilizer by spot-stripping the plastic coat from the rear spar and spar doubler, in hopes of leaving enough to protect the alclad.
Then Houston went to town clecoing these pieces together.
Spot-removing plastic from rear spar & doubler
ClecoMan!
ClecoMan!
Cleco the rudder hinge mounts
