Sid & Houston Mayeux Project
Date:  11-12-2010
Number of Hours:  1.00
Manual Reference:  Problem
Brief Description:  Problem with Horiz Stab front spar
I may have made a goof on the horizontal stab front spar. When I cleco'd the two halves of HS-702 to the HS-710 and HS-714 reinforcements, I misread the diagram and used the wrong holes. You can see the gap between the two 702 pieces in Image 1. This resulted in mismatched holes at the HS-702 attach points (image 2).
I'm standing by for words from the Mother Ship and the brothers at Van's Air Force on whether:
- I compromised this assembly's strength?
- Do I need to order two new HS-702s?
- Or is there no worry here?
- Or a method to preserve the strength?
ClecoingHS-702 halves to HS710/714
Unmatched holes on front spar
