Sid & Houston Mayeux Project
Date:  11-11-2010
Number of Hours:  1.00
Brief Description:  Horiz Stab--Disassembly and final front spar holes
After removing the horiz stab skins, Houston drilled out the outboard mounting holes between the front spar and the two reinforcements. Next up: Deburring, edging, dimpling, then priming.
Not a bad 6 hours on Veterans Day! Well done, Houston!
Houston drilling the final front spar holes
