Sid & Houston Mayeux Project
Date:  11-11-2010
Number of Hours:  1.00
Brief Description:  horiz stab inboard ribs placement
The inboard ribs are not match-drilled, so we had to be sure and place them properly in relation to the forward and aft spars, then clamp them. The skin has pre-drilled holes, so I could mark through the holes onto the ribs' flanges with a sharpee, mark a centerline reference on those flanges, then reposition the ribs and clamp them again. With small adjustments I found those reference marks and started drilling......
Aligning the ribs, then clamping them down
In place!
In place!
