Brief Description: Rivet on HS-707 to HS-601PP Skin
Clecoed and then riveted on HS-707 Nose Rib to the skins. I did both sides simultaneously just to keep everything consistent. Really had a hard time getting the forward most rivet in and set. Had to use an Oops rivet here. You can see a little bit of a "dent" on the second rivet. This was hard and easy to lose your concentration. Only takes a second to do this. I'm not complaining but you try for perfection and you have to realize it's not going to be. Once the HS is finished and all the blue is taken off am going to buff the shit out of it and make it shine so I'm not too concerned about it. I'm learning so much about this process. I almost reordered the skin and started over because that is how I'm built. I expect perfection. Luckily my wife talked me off the ledge and told me to just roll on with what you got. She has a point and that is if I reorder everytime I make a mistake I will spend twice as much. So with that I'm rolling on and making it the best I can. Paint will cover up little imperfections like this.
