Brief Description: Install Brake Master Cylinder, Wire Nav & Strobe L
Install brake master cylinder on flap handle.
Install correct length bolts on sides of landing light mounting brackets: Left outside: AN3-3A Left inside: AN3-6A Right outside: AN3-6A Right Inside: AN3-3A
Wire Nav & Strobe lights. Nav Red & Strobe Yellow to cable Red. Nav & Strobe ground to cable Black. Strobe Sync Blue to cable White
Cleco W22-01 L&R Tip Rib to wings. Rivet same, using AAP-44 rivets (from Sonex, AL/AL rivet/shank).
