Brief Description: Move Flap Control to Center of Cockpit
Fabricate spacers for flap drive block at center from 1" x 1/2" bar stock, install same, and also install all other parts for flap handle installation at center instead of at left side of cockpit. Rivet 2" square tubing to F16-01 Fuselage Lower Forward Skin. Drill F24-05 Lower Cross Tie #1 and flat stock reinforcement plate 3/16" and deburr. Remove AN42B-17A and install AN42B6A Eyebolt. Rivet reinforcement plate.
Install ACV-Q01-40 Cable for Dial-A-Trim, springs & hardware. Adjust spring tension.
