Brief Description: Fabricate & Install Main Gear Leg Fairings
Fitting L07-07 L&R Fairing Assembly to main land gear legs, connect brake lines.
Brake line and fitting info:
Brake line: NylaFlow Type H, A/S 05-04355 or Sonex provided tubing, no P/N. 90 degree caliper fitting x2 from Sonex, no P/N. Tee at master cylinder: NAPA P/N 3700 1/8" Female NPT x3 ports 1/8" NPT Male x 3/16" compression fitting straight, A/S 268P-03 x2 1/*" NPT Male x 3/16" compression fitting straight, no P/N x1
