Replace temporary standard nuts on the engine / main landing gear mount where it attaches to the fuselage, using AN363-428 metal lock nuts. Use cutting oil on bolts.
Tool used: Phillips bit #CR-VRH3 Screws used: Bottom Right, Bottom Bolt MS24694-S98 + 1 FW Bottom Right, Top Bolt MS24694-S98 + 1 FW Bottom Left, Bottom Bolt MS24694-S98 + 1 FW Bottom Left, Top Bolt MS24694-S98 + 1 FW Top Left, Bottom Bolt MS24694-S99 + 1 FW Top Left, Top Bolt MS24694-S99 + 1 FW Top Right, Bottom Bolt MS24694-S99 + 1 FW Top Right, Top Bolt MS24694-S99 + 1 FW
Install fuel fittings from fireall to Aero Injector.
