TERRY'S WEB SITE
Sonex
Install Engine Sensors
Drill 13/64" ACV-E01-20 & -21 Left & Right Exhaust Manifold for EGT Thermocouples x 4.
Install same.
Install MGL LM335 Oil Temperature Sensor into ACV-P01-12 Oil Temperature Plate, below cylinder #2.
Install MGL Resistive VDO 10 Bar Oil Pressure Sensor 100 ohm, 145 PSI.
Install instruments into instrument panel.
Instruments Mounted in Panel #3863
Instruments Mounted in Panel #3864
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
