Brief Description: Mount Ignition Coils, Aero Injector
Mark location on firewall for ACV-A01-25 x 2 Ignition Coil.
Install ACV-C07 32 mm Aero Injector to ACV-M01-10 Intake Manifold Assembly.
ACV-C10-30 Air Filter Assembly -Bolts to hold filter in place are too short -Instructions say to "slide the air filter onto the intake bell as far as it will go". Obviously incorrect. Bell on my injector does not match picture in the instructions, picture shows straight vs. bell shaped on mine. Drill and tap for AN3-12A bolts vs. the provided sheet metal screws.
Fuel fittings: To ACV-C07 Aero Injector FBM2033 1/8" Male x AN6 Male Fuel Filter Edelbrock 8130 (replacement filter is 8133) To filter Russell 610020 AN6 Female to AN6 Hose x 2 Fuel tank Russell 610020. AN6 Female to AN6 Hose
