Continue AeroVee engine assembly. Lube tips of push rods, insert for cylinders 1 & 2. Install ACV-P02-10 Rhino Rocker Arm Assembly, torque nuts to 168 in/lbs. Repeat same for cylinders 3 & 4. Adjust valves / rocker arms for .006" clearance. Install ACV-P01-53 Oil Change Kit, p/n 113 198 031, made in Germany. Install oil screen and ACV-P02-20 Machined Oil Sump Plate using gaskets and copper washers from oil change kit and ACV-Z01-22 6 mm nylocks. And guess what the studs are not long enough to even engage the nuts on the threads using the machined plate.
I keep wondering if I am the first one to build this engine kit and options.
So I ended up using the cover plate from the oil change kit, but then had to grind off one side of it to clear the case.
Drill and tap ACV-P01-12 Oil Temperature Plate for 1/8"-27 NPT for the oil temperature sensor. Install same on engine with gasket and ACV-Z01-23 x 2 nylock nuts.
Install ACV-P01-14 Fuel Pump Block Off Plate, gasket, ACV-Z01-18 x 2 Bolt. Install ACV-P01-17 Oil Filler Plug.
Install ACV-P01-11 Oil Bypass Plate & gasket using ACV-Z01-19 Bolt (M8 x 1.25). Bolts will not screw into case! Bolt is also too long.
ACV-P01-55 Maxi Oil Pump bolts x 4 (M8 x 1.25) will not screw into case !
Mask off engine, paint same, using Rust Oleum Flat Black High Temperature Paint
