Double check fit of ACV-P02-10 Rhino Rocker Arm Assembly on #1 & #2 side. Final fit:
Install 2 spacers under each mounting block. Cyl #2 Valve Side Cyl #1 .015-.030-R-S-R-,030--,030-,030-1.748S-.030-.030-.015-R-,015-S-R-.030-.030 Push Rod Side Install assembly on cylinder head and torque.
Double check fit of ACV-P02-10 Rhino Rocker Arm Assembly on #3 & #4 side. Final fit:
Install 2 spacers under each mounting block. Cyl #3 Valve Side Cyl #4 .030-.015-R-S-R-.030-.030-.030-1.745S-.030-,030-,030-R-.015-S-R-,030-,030 Had to trim right side of right spacer to obtain free play in assembly. Push Rod Side Install assembly on cylinder head and torque.
Cylinder #1 & #2 Rocker Arm to Valve Alignment #3825
Cylinder #1 & #2 Rocker Arm to Valve Alignment #3826
Cylinder #1 & #2 Rocker Arm to Valve Alignment #3827
