TERRY'S WEB SITE
Date:  12-27-2014
Brief Description:  Continue AeroVee Engine Assembly
Calculate cylinder barrel shim thickness.
Assemble a piston & cylinder barrel assembly, install onto #1 connecting rod, seat cylinder to crankcase.
Measure deck height:
-.004" to -.005" (minus value means piston is above cylinder)
Chart shows qty 1 .060" shim.
6 of 8 cylinder head threaded inserts on the left case are above the shim / barrel seating surface.
This will have to be corrected.
Elegant engine package? NOT !
