Fit D02-03 Windshield Bow & D02-04 Forward Bow. Cut D02-01 Windshield to width at front to wrap around F17-02 Upper Firewall Assembly, taper this cut back to the aft end of the Windshield, cutting nothing off of the aft end. Pull Windshield Bow up to meet Windshield, dis-regarding the Bow angle called out in the DWG's. Using this angle would result in the Windshield being too low, therefore resulting in a not so smooth transition between Windshield and Canopy. Install nut plates x 5 on F17-04 Windshield Strap.
