TERRY'S WEB SITE
Date: 12-14-2013
Number of Hours: 3.00
Brief Description: Embennage Work
Deburr F23-01 Tail Spring Mount. Remove T08-01 Vertical Stabilizer Assembly, drill 2 top holes in F23-01 Tail Wheel Mount. Dissassemble & remove T02-03 & T06-02 Elevator Root Assembly. Trim inside ends of T07-01 L&R Elevator Skin.
Reassemble, cleco & rivet T02-03 Elevator Assembly & T06-02 Elevator Root Assembly to T07-01 L&R Elevator Skin.
Remove bolts through T02-01 Horizontal Tail Assembly & F26-02 L&R Upper Longeron & uncleco from F25-01 L&R Side Panel Assembly. Remove F23-02 Bulkhead, F22-05 Aft Angle. Rivet both together, reinstall & cleco.
Bolt T02-01 Horizontal Tail Assembly to F26-02 L&R Upper Longeon, cleco to F25-01 Side Panel Assembly.
Deburr top & bottom of F22-01 Aft Fuselage Floor. Deburr bottom of F26-03 L&R Lower Longeron. Cleco F22-01 Fuselage Floor to F26-03 L&R Lower Longeron, drill 6 holes #40 & #30 in F26-03 for F23-04 Aft Lower Mount Angle. Remove F22-01 Aft Fuselage Floor, deburr the 6 holes.
Drill #30 F26-02 L&R Upper Longeron & F12-05 Angle, dissassemble, deburr, reassemble & cleco, rivet same.
Install T02-03 Elevator Assembly, insert hinge pins. Finish riveting T06-02 Elevator Root Assembly to T07-01 L&R Elevator Skiin.
Cleco F23-04 Aft Lower Mount Angle to T09-01 Vertical Stabilizer Main spar Assembly. Drill #30 through same & F26-03 L&R Lower Longeron.
Elevator Root Assembly & Elevator Skins Assembled #3022
Elevator Root Assembly & Elevator Skins Assembled #3023
