Install,bolt & cleco T08-01 Vertical Tail Assembly to fuselage. Install T08-02 Rudder Assembly. Check for rudder travel per DWG SNX-T01, looks good, 25 degrees deflection left & right.
Drill & cleco T10-07 Lower Elevator Hinge Half to F26-01 Aft Side Panel Skin. Bolt T12-05 Angle to T12-01 Main Spar Aft Strap, F12-04 Lower Spar Channel.
Drill #40, #30 T12-05 Angle through F26-02 L&R Upper Longeron. Dissassemble all, deburr, reassemble.
