TERRY'S WEB SITE
Sonex
Controls & Horizontal Stabilizer
Fit SF812-4 Symco Bushing to C05-02 Control Stick Assembly, C03-06 Elevator Push Rod, C03-05 Elevator Push Rod End.
Drill #30 & cleco F23-01 Tail Wheel Mount forward tab / plate to F23-03 Forward Lower Mount, F23-02 Bulkhead.
Trim edges of T05-01 L&R Horizontal Stabilizer Skin, T11-01 Vertical Stabilizer Skin.
Fit T02-01 Horizontal Tail Assembly & T08-01 Vertical Tail Assembly to F21-01 Fuselage Tail Cone Box.
Install T12-05 to T09-01 Vertical Stabilizer Main Spar Assembly.
Clamp F23-04 Aft Lower Mount Angle to F26-03 L&R Lower Longeron.
Dril #40 aft tab of F23-01 Tail Wheel Mount from forward side of F23-04 & T09-01 & cleco.
Drill #40, #30 T09-01 Vertical Stabilizer Main Spar Assembly through F26-01 L&R Aft Side Panel Skin & cleco.
Remove T02-01 & T08-01 & deburr.
Install & cleco T02-03 Elevator Assembly (hinge) to T02-02 Horizontal Stabilizer Assembly.
Drill access holes in F26-01 L&R Aft Side Panel Skin.
Sonex Home
2005
Aircraft Kit
Aircraft Kit Details
Canopy #2
ELT
283
212
Engine Cowl
54
154
480
Hardware Kits
Hydraulic Brakes
Instrument Panel
Weight & Balance
Wheel Pants
538
Workshop
