Bolt C05-07 Link Rod to C04-08 Control Stick Horn Assembly. Rivet & bolt: F16-02 Forward Tunnel Zee to F16-03 Aft Tunnel Web Assembly F16-08 x 2 Side Clip to F16-02 Forward Tunnel Zee, F13-01 L&R Forward Fuselage Side Skin, F16-03 Aft Tunnel Web Assembly
On F12-01 L&R Forward Fuselage Side Panel, rivet: L04-01 Tri-Gear Main Gear Mount F14-11 L&R Gear Attach Angle F15-09 L&R Lower Gear Gussett Plate F14-09 L&R Aft Wing Attach Angle F14-13 L&R Horizontal Angle F14-10 x 2 Gussett F15-10 x 2 Upper Gear Gussett Plate
