Brief Description: Left Wing Aft Rib, Main and Rear Spar
Drill #40 and cleco 2 center holes on: W15-01 thru -04, -05 x 8 Fwd Rib W16-01 thru -04, -05 x 8 Aft Rib W14-02 x 10 Center Spacer W14-03 x 8 Web Spacer to W08-01L Left Main Spar Drill #40 and cleco the remaining 4 holes at each location. Drill same #30 and cleco. Drill #30 and cleco: W16-01 thru -04, -05 x 8 Aft Rib W13-04 Doubler W13-01L Left Hand Attach Plate W13-02L Left Root Rib Attach Angle to W12-01L Left Rear Spar Drill #40 and cleco W10-06 Tip Attach Angle to W08-01L Left Main Spar, Drill same #30 and cleco.
