Brief Description: Attach Misc Parts to Left Main Spar
Drill 1/4" W11-07 Root Attach Angle and W11-03 Wing Attach Block and assemble. Bolt same to W08-01L Left Main Spar. Drill 3/16" and install W11-11 Outboard Vertical Stiffener Angle and W11-10L Left Hand Tie Down Fitting to W08-01L Left Main Spar. Cut off 3/8" from aft end of Fwd Rib on W17-01L Left Root Rib Assembly. Trim notches on rib to clear main spar. Check fit of notches cut on W15-01 thru -05 Fwd Rib to W08-01L Left Main Spar, all are OK.
