Clamp W12-01R Rear Spar to bench. Uncleco W08-01R Main Spar from W16-01 thru -12 Wing Ribs and W17-01R Root Rib. Debur holes on all. Unbolt W11-1 Outboard Vertical Stiffener Angle, W11-10R Right Hand Tie Down Fitting from W08-01R, debur all. Reassemble W11-10R to W08-01R, with Qty 1 AN3-7A, 1 AN960-10 washer under bolt head; Qty 7 AN3-6A, 2 washers under nylocks.
